f355spider
$50 Site Donor 2026
I reread the IFUs for both the 2012 and 128CEC2. It makes no mention of capacity differences, but if the batteries are not properly desulfated in advance, the desulfation will favor the largest battery in the group. So they recommend desulfation is performed individually, not as a group. Once they are desulfated, they can be maintained as a group...but again, the smallest in the group may not benefit as much as the largest battery.The question the is, what if I have about 4 flooded sealed batteries of different capacity?
There may be something to this, which I will need to test. One of my BMWs has two batteries (they are original Varta and 6+ years old), an H9 AGM and H5 AGM. I use the Y adapter from Battery Minder and have them on the 128CEC2 for the past two years or so. The H9 is rated at 950 CCA and tests at well over 1000 CCA, while the smaller H5 rated at 660 CCA is testing around 569 CCA. Still passes the test as a "good battery", but I wonder if a month or two on the Battery Minder maintained separately might improve the results? I just went out and removed the Y adapter and have it maintained by itself. I'll report back in a month.
