Barely used oil in mowers?
Southeast Texas
Pennzoil conventional, 10-30, in Chrysler car sitting for 15 months, started up maybe 8 times. Less than 1 hour total run time on oil. Would it likely be OK to use in two mowers (5 years and 10 years old) I maintain? Opinions? Thanks...
I'd be concerned with excess moisture and oxidation in this oil, even if it wasn't used much. Then again, we're talking about a 10 year old mower here - it'd probably be OK, although depending on the mower engines, some actually seem to run better on straight 30 oil.
If possible drive the car for 20-30 miles on highway to burn off moisture and fuel dilution if any, then drain it while hot to use in the mowers.
Yes. Actually it will have to be driven 45 miles highway when it comes out of storage to get it home. Pennzoil conventional supposedly holds up well, so, I am thinking it won't hurt the mowers much if any. I am not "cheap", but I hate to waste usable oil..
Ran mobil 1 in a lawnmower for 10 years. Finally changed it. It did run a lot better, but it apparently did no damage. 5 years later the thing is still running, although I change it every season now.
No problem...
Dad had an old Briggs & Straton with 10 year old oil in it never changed with like a hundred hours on it and it was fine so your Chrysler used oil should be no problem.
All I can say is there are PLENTY of mowers out there with MUCH worse oil in them. I have a few machines that don't get used much, the oil looks pretty good 6-9 months out. It may be a good use of the oil rather than tossing it.
My question is why bother changing the oil in the car if it has only been run a few times?
It will be 15 months old. The car will come out of storage when my daughter starts to drive, and since we live in a small town, it would take another year to even put 2000 miles on it. So if I left it in, it might be 2.5 years old before changing. I figured I would just drain it and save it for the mowers, and keep the almost new filter in place, and put in something like QS for about $11.
If the oil doesn't look odd when draining from the car (mayo, snot, pools of water, fuel, sludge) I think you're good to go.
If you're one of those rural types with outbuildings and sheds with workbenches, you could heat the oil to near boiling and see if any moisture boils off. Probably not worth it for a lawnmower. Oh wait - south Texas? Just leave it in the sun for a bit.
You may also wish to pour through a coffee filter before transferring.
Sounds like a lot of thought and work. If you want to change it, then change it, but I would just recycle it and spend $2 on a Qt of oil for your mower. Personally I would just run the oil for a few thousand and change it out then, I don' think there is anything wrong with 2 year old oil.
Personally, I've never had an issue with leaving oil in an unused engine for years. I'd be more concerned about firing the engine up a few times a year to keep all internal parts coated with oil. Run the engine to full operating temps and most condensation should cook off.
As far as using the barely used oil from the car in the lawn mower, I say go for it. Lawnmower engines aren't particularly fussy. At least none that I've owned.
+1 to that. I do it all the time. The oil comes out like it looked in the bottle if you decided to dump it.
Joel
