"Old oil OK for 20-min flush?"
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=14;t=000201 is a bit old and this is sort of a different matter.
Same oil (10, 15, or more years old but in sealed containers) and same mower. FWIW, mower engine seems to have eaten a fair amount of oil through the summer (more than its capacity) and the oil was very black (I have until spring to decide: Should I do Auto-RX, then LC, in a GC or Diesel-rated 15W40, or use crappy oil until it dies?)
This old oil that is OK for a 20 minute flush: What about draining the oil now, in fall, and refilling with this old oil. Then in spring either run 20 mins and drain after the engine runs (certainly under 1/2 hour) on the old oil, and replace with (new) straight 30 (as the manual & dipstick say) or something like the aforementioned HDEO / 15W40 / GC / Redline, etc.....I just somehow sense there is something wrong with this plan.
If the old oil would be OK for a 20-30 min "flush" why wouldn't it be fine to sit in the sump for 5 months? Again, to be clear, I do not want that old oil *running* more than 30 mins before discarding it.
Thanks!
Rob-the-oil-nut
Thanks!
Rob-the-oil-nut
