I don't use one. I simply crank the heat up to 600+ for a few minutes after grilling, and then wipe it with a blue scrub sponge once it cools. Everything simply wipes off and is ready for next time.
No brush. Heat up the grates and scrub lightly with a wad of aluminum foil. Works like a charm.
Once a year I pull all my grates from the grills and smokers, put them in a black trash bag when it's 90+ outside and douse them with oven cleaner. Tie up the bag and let it sit for 4-5 hours letting mother nature handle the heat. They come out spotless.
I like keeping them clean and heat doesn't cut it with me - certainly not "spotless" and the residue does promote sticking and hot spots on the food - like cheap cookware makes hot spots in a pan.
The drill I have is a bottle of olive oil by/under the grill. Wet a paper towel and wipe the grates before cooking. As food comes off, run them over quickly with any old grill brush. Clean and fresh for next time.
Originally Posted By: dishdude
I never clean the grates - added flavor. They frequently catch fire!
Ahhh... the old Bundy Burger method:
Originally Posted By: Al Bundy
Last year's grease on the grill, last year's ashes on the bottom. That's what makes a Bundy Burger special.
Mine uses a stainless steel scrubby held in place with two pins. The thing lasts for years. Don't remember the name though. Replacement scrubbies are available.
Doesn't rust, works better than a brush at cleaning and lasts a long, long time.
