baldwin bypass
ks, wichita
moe in wichita ks
i hope iam not posting somthing that has allready been posted.
i found on u-tube these baldwin numbers.
ob1305 filter head
bt341 spin on ellement by-pass low micron rating
filter head may be obi305.
There's a former member who ran this filter in tandem after buying threaded adapters for his permacool dual mount. They have a restrictive orifice built in. Here it is in Wix.
Part Number: 51051
UPC Number: 765809510517
Principal Application: IHC 100, 200, 240, 340 Tractors
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: By-Pass
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 5/8-18
By-Pass Valve Setting-PSI: None
Burst Pressure-PSI: 350
Max Flow Rate: 1 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
The filters are used in industrial engine that have a bypass not a full flow oil filter system,What is real funny is engines that use full flow oil filters last 2xlonger than the same engines with the bypass only filter setups I noticed thes when I had a real job. I am retired now.
A few people on this site, including me, have installed this Baldwin setup in bypass. It probably does not filter quite as well as the best setups, but it also costs less. In my case, given the availability of the short filter option (BT341), it fit better in the space I selected than the larger filters would have. I could have squeezed in a larger filter, but it would have been just touching the skid plate - too close for me.
