I have two chipper shredders I got for free a while ago. One is an MTD 5HP and the other is a Craftsman 9HP. The bodies are identical and all parts interchange. I am looking to combine the best parts and build up a decent chipper shredder. Both engines work well after carb rebuilds and general cleaning. The issue I have is both of these chipper shredders sat outside for a while causing water to pool inside causing the flywheel to rust, creating severe balance issues and vibration. The flywheel weighs probably 25 pounds or so with no blades on it. One is severely rusted which will end up at the scrap yard. The other flywheel looks to have minor rust on one side and could be easily balanced. The question I have is; What kind of balancing device would I use to balance such a heavy flywheel? Also; What is the preferred method to add or subtract weight to this flywheel. I have seen where people have drilled heavy spots only to have debris get inside of the holes and clog things up or knock it off of balance.
I couldn't find anything on Google or YouTube.
