Vehicle in question is the S10.
Driving to work last night all of a sudden the dash and lights went dim, radio popped, and then all the warning lights lit up and went off like a normal key cycle. This did this several times, but the vehicle never stalled out, and restarted fine. Coming home it seemed to happen sporadically, but mostly only on left turns? I jiggled the ignition hard and it did not do it. Engine never cut out or stalled. I looked and it appears the ground going from the engine to body looks like it has a case of some green corrosion on it near the engine block. I pulled on it, but still seems attached. Does this sound like possibly a ground issue?
