- Joined
- Jun 3, 2021
- Messages
- 829
The A/C in my Accord stopped working one day, just overnight. It only blows lukewarm air now. Now, the pulley on the A/C compressor spins freely at all times with the serpentine belt, but the inner portion inside the pulley does not spin with the A/C on nor does it spin even if you try to spin it yourself with the car shut off. This means the compressor clutch has failed, correct?
The thing is I also hooked up an A/C pressure gauge to the system and it reads very high, outside the normal desired pressure range. My concern is, if the clutch wasn't actually allowing the compressor to function (hence the lack of cold air through the vents) then why would my pressure read high? Shouldn't it read very low?
