2017 Forester A/C
USA
A couple weeks ago AC worked for 5-10 minutes then would blow warm. Would repeat the process every time you shut it off, got gas, ran into store, etc. I took the clutch off and removed one shim as the air gap was over 0.8mm. Worked great the last two weeks! Until today again. It was being intermittent again so with it off I swapped relays under the hood. Worked when I drove it around. Got a new relay from AutoZone as they were the only one open and/or had one in stock on their website. Blew cold the entire 20 minute drive home.
If it continues, what's next? Pressure check again? Check the plug is getting 12v when it dies to know if it's something in the dash or the coil/magnet in the compressor itself?
I'm getting to the point where it might just be a dealer $$$$$$$ fix if it acts up again with the new relay. There might be clutch and coil magnet kits I can get, not 100% certain, is that worth it? I've read these compressors are sketchy and so are the relays and at some point just spending a lot to fix it for another 100k I'm fine with. Am I there yet if the relay wasn't the fix? I'm annoyed with it but can't stop myself trying to troubleshoot it on my own 🤣
You may just need a new clutch plate(cover) which are easy to replace. Sometimes they engage and other times they don't.
Often there are shims under the clutch plate and you can remove one and see it this works for you along with a top off of refrigerant. This may not be the exact video that you're looking for but, it'll get you close.
Good luck!
I bought a 2018 forester new. The AC never worked well ... most of the time it never worked at all.
multiple compressors, condensers , a set of lines and o-rings and I sold the car with non functional AC at 4 years old to Carvana.
Yeah I removed a shim. It worked for a few weeks then intermittent again. So I just replaced the relay. The clutch engages when it engages. Seems just fine when I watch it. But other times it doesn't engage and I'm assuming, after removing a shim, it's either the relay that I just replaced or refrigerant is low (but when it works it's cold and fine so I'm guessing not refrigerant) or the magnetic coil is bad.
I had a 2019 and there was a recall on something with the a/c, I think they replaced the condenser. It worked great but I sold it since I was having transmission problems.
That's been completed about 5 years ago. The AC is trash in Subarus even when it's working though.
