B164-B50 filters
Houston,TX
Just thought i would share info i recived from Baldwin on monday about theses two filters.
B164 Media grade L3-130 760 sq" B15=75
B50 is the same with only 579 sq" of media.
Saw some older post talking about much higher ratings.
Looks like Ill need to keep looking if i want a better spin on. (without getting the ea100)
They are just "OK" a little better than a fuel flow,
and not as good as some fuel/hydraulic filters (many fuel filters are only good to 10 μ, anyway)
I do run one (it's actually a Hastings LF334) before the oil goes to my "finer" bypass oil filter.
Also - don't forget - - - the slower the oil flows through the media, the better it traps contaminates.
After I said all of that - I doubt you'll see any benefit from running a bypass oil filter. We shall all see, I suppose.
I think the info I got was 15μ absolute...
and about 5 micron nominal (50%)
That's no too bad.
Not as good as the good 'ol roll of TP, though....
Not bad though for a: sandwitch adapter ($23),remote mount ($35), B50 filter ($7.50) hoses, clamps and one swivel fitting ($28) for a set up on one of my trucks. I'll take 15u absolute and 5 nominal at 50% any day. I do run TP filters as well, but the Baldwin B50 does provide good results for the low cost of a total setup.
nuff said,
xtell
