JHZR2
Staff member
I’ve talked about having a few older Snapper Hi-Vac mowers. One of them has a 3.5Max engines. It starts perfectly, runs great, but it does clog somewhat easily.
I figured since it was new to me, I’d give it a full service. I know the one thing I noted when I pulled the air filter, it seemed to be dry but as if it had been soaked with gas. The replacement with maybe 10 hours is the white one. You can see then yellowish color.
I figured this meant something was slipping by the carburetor or who knows what else, and regardless, it would be prudent to service the carb.
I pulled it, it’s pretty darn clean.
It seems clean inside:
I got a refurb kit. I’m not sure I need all the parts.
The instructions talk about removing Welch plugs, but I’m not really clear if all the parts in the kit are necesssary, and if I need to do much with them.
I’m not even really certain why the Welch plugs need to be removed.
I’ve looked at a number of videos online, including with carburetors like this. I don’t get much about pulling the Welch plug, and what else to do.
Taking apart and refurbishing the carb on my JD Kawasaki was super easy. I can’t imagine this is terribly complex. Does anyone have recommendations on what I should do on this unit while I have it out and open?
Thanks!
Thanks!
