Prof Sid Watkins says he took it off.
You can see a cervical collar clearly in the documentary.
Cervical collar can't be fitted with helmet in place.
Helmet off is the first stage in trauma care.
Airway takes priority over any injury or risk of paralysis.
Basic premis of pre hospital trauma care is life takes precidence over limb.
Ayrton would have been RSi'd on scene and sedated.
This was standard procedure in the early HEMs helicopter in London, which is why it was the first Air Ambulance to carry a Dr and take on the HEMs name, Helicopter Emergency Medicine Service as apposed to the traditional Air Ambulance with a couple of Paramedics on board.
I have reviewed the documentary footage and the only clear image is when Ayrtons chest is exposed and the collar is clearly seen, at roughly the same time you can see the vacuum stretcher being unravelled, this forms a stable imobilisation of the patient and is gold standard trauma care, have only used it twice when doing a fall from height with the HEMs team, it is like a large vacuum splint.
I can only suggest that anybody in doubt reviews the footage.
And listens to the comments of Prof Sid Watkins, one of the most senior and experienced Drs in this field.
Removing the helmet is not optional, you have no control of C spine or airway and are unable to access the extent of a head injury.
Basic of emergency medicine, primary and secondary survey. Expose and examine.
I would take Prof Watkins statement over anything in the press. There is no situation where a helmet is impossible to remove.
Anybody that says otherwise is mistaken.
Would i believe anything written by a non expert in the field over one of the senior Drs on scene?
No, i wouldn't.
