Originally Posted By: badtlc
Originally Posted By: gathermewool
Why not 87 octane? V-Power is only offered in the highest octane, right? Around here, that's 93. If that thing calls for 87 AKI, what's the benefit of using multiple tiers higher?
This has been covered many times but modern engines, especial DI engines have the ability to control AF ratio in addition to timing based on octane. If you run premium in a skyactiv, it not only advances timing but leans out the AF ratio which improves MPGs and reduces fuel dilution in the oil.
When running 87 in such a high compression engine, the ECU has to run pig rich to keep the combustion chamber temps down and prevent detonation. It works fine but there are better options if you prefer.
Was it covered by you and other members or by a tuner and/or some white paper?
If the ECU tables only allow for fueling, ignition timing, and valve timing based on 87 octane (or slightly higher) it literally cannot account for the higher octane. The ECM should attempt to advance ignition timing, adjust fueling and vary valve timing to the the threshold of knock. If 87 octane fuel is beyond this threshold, then even using 89 would be a waste. If 89 is more appropriate for a skyactiv motor, then 91 would be a waste.
Not every state offers 93 octane and some states only offer an inferior 91 AKI as their premium fuel, so it's hard for me to believe (maybe wrongly) that a manufacturer would tune an engine to take advantage of this much variability without so much as recommending a higher octane than 87, even if it was solely to gain that extra bit for marketing purposes. Mazda does only recommend 87 or higher, right?
So, I guess I'm asking how you know that your ECM is taking advantage of premium fuel. I'm very interested in a Mazda as my next vehicle, and would love to know of any hidden gems that would make owning one that much cooler.
