ls1mike
$50 Site Donor 2026
Usually some chatter here about them for people towing or just adding one for piece of mind. I had an aftermarket one on the truck for 9 years. Went to change the clamped on lines and broke a weld.
So I decided to get a bigger one. I will report the decrease in temps after towing next weekend. Depending on where I am and ambient temps with a gross combined weight of 14200ish to 14500ish I will see temps anywhere from 165 to 180 just cruising on the flats and 190 to 220 when pulling grades or using the go pedal to get up to speed. If there is traffic or I am going slow it takes a lot longer to cool off or will heat up quicker as not as much air flow. Summer it usually hangs around 180 to 190 when towing.
It will get warm enough without a load as today just running around it hit about 125. Torque convertor lockup can occur at about 80ish degrees.
Cooler has a built in bypass (sort of) as the fluid gets warmer more will flow through the main portion of it.
The folks on the GMT 800 board say it is the best upgrade they have made for towing. This is also true of people running other types of tow rigs.
It keeps overall temps lower and cools off hot fluid much quicker.
The new one
The old one
Some install photos.
I was able to use the factory fitting and line from the radiator out to the cooler. I had to cut the return, flare it and used clamps. The old one use clamps for the complete install.
The new one
The old one
