Originally Posted By: jmsjags
the code that the scanner gives you tells you exactly what's wrong. just hop online for 5 minutes and do a google search for the code. then fix yourself.
I'm going to have to disagree with you here(like everybody else).Sometimes it is a bad sensor but not always.
My moms car throws a P0101 code all the time.
http://www.obd-codes.com/p0101
Guess what? A brand new $180 map sensor did not fix the problem. Neither did a $20 used one from the junkyard.
So we know that something is wrong with what the map sensor is telling the computer but what is it? It's not the map sensor it's self.
How about a misfire code? Is it a plug? Wire? Coil?, Injector? Wiring to the injector? Broken valvespring? Loose valve guide? Missing or damaged valve stem seal letting oil foul that plug? Theres no way of knowing with out the proper diagnostics.
