AutoRX Order
Alabama
OK, I'll bite. I have been lurking here for some time and I keep coming back to AutoRX. I finally took the plunge and ordered 4 bottles. I will initially use it in my '92 Mazda B-4000 with 135,000 miles. It currently runs fine and uses no oil between changes. I will pull the plugs and check the compression 'before' and 'after'. I have never had the valve covers off so I really don't know what it looks like down there. I have always used 10-30 dino (various brands), changing between 3000 and 4000 miles. I have never had any engine problems. I'll be reporting back after the treatment is completed. If I were to try to open up an oil filter, how can that be done without slicing my hand in the process? I think this would be too messy to do with my band saw.
Nail two blocks of wood to the work bench to set the filter between. Drain the filter with a nail holding back the antidrainback valve or puncture the other end. Set filter between blocks to hold it steady and cut with hacksaw rotating the filter. I usually cut the threaded end off about 1/4 inch up the can. Ignore metal bits since you are looking for sludge with ARx.
If you have an air compressor you could go to harbor freight and buy one of their $15 cut off wheel tools. It has a spinning 2.5" fiberglass wheel that will cut it in a snap and the 2x4" idea is a good one, makes quick work of it but its a little messy as said so wear some nitrile or latex gloves, cut 1/4~3/4" an inch above the base of the filter.
A Dremel tool with a cut-off wheel should be quick and relatively clean.
Thanks for the suggestions folks. I hadn't thought about the drain-back valve. I already have the HF cut-off tool. Good Idea.
There are special tools to do this. They are basically modified pipe/tubing cutters. The one I got to use spans the threaded end of the filter and uses the threaded hole for a guide pin. The non-handle side has a wheeled tightener ..the handle (under it) has a cutting wheel (tubing cutter). You just keep moving it around and tightening the grip as you crease the filter. No debris.
But a 4" pipe cutter should do it just as good. I'm sure Harbor Freight has a cheapie.
Err...looks like this one only goes up to 3.75" ..but it fits a FL1A el cheapo oil filter opener - no debris
[ September 01, 2004, 07:59 PM: Message edited by: Gary Allan ]
Nice find. I bet it works at least as good as the ~$40 special filter cutter I just got from Summit. I should have looked at HF first, we have a big HF store less than 20 miles from where I live.
