Automotive synthetic oil
FL
Has anybody used automotive motor oil (specifically synthetic) in their outboard? I have a Mercury 4-stroke 25 hp outboard and I normally change the oil once a year with Quicksilver 10w30 (as recommended), but it's hard not to notice all of the clearance oils going on at WM. I especially noticed a qt. of Quaker State Ultimate Durability 10w30 on clearance at $2.50 and I was wondering if it would be o.k. to mix that with a qt. of Quicksilver (my outboard calls for 2 qts. of oil). FWIW, the motor is no longer under warranty.
Do you use it in saltwater? The advantages of the marine oil are better water emulsion and corrosion resistance. If you were here where there is only freshwater a non-energy conserving 10-30 or better yet an HDEO 10-30 would probably be fine.
I also have a Mercury 4 stroke. As far as oil goes, what did you pay for a quart of Mercury's oil? Multiply that times the number of quarts to change. Now divide that number by the cost of the motor. What you get is a number that's in the tenths of 1 percent of the cost of the motor.
Save money by drinking cheaper beer ;-)
Originally Posted By: Doog
Not in salt water. Stick with the Quicksilver. I have used it for 30 years and never had an issue.
Merc hasn't had four strokes for thirty years but I agree it's a good oil. For the minor cost difference I would stick with it.
Any 10w30 will be fine.
Around here Pennzoil is popular.
Quicksilver is a great oil but its nothing special.
