I have located one leak . The Schrader valve at the low pressure service fitting . Loosened it off a little and tightened it up agan , 3 - 4 times . In hopes it would seal . No real luck . I need to change it out .
I have the tool to do so on my home R-22 condenser unit , with out releasing more than a minimum of refrigerant . Would like to find the equivalent tool for R-134a low side fittings .
If one of you can give me the correct nomenclature , I will run a google search for it .
Thanks ,
Thanks ,
