I am changing the transmission fluid on a 2008 vw Jetta 2.5. Since this car doesn't have a dipstick there is no easy way to check level after it is all buttoned up. The basic procedure I am using is fill, get up to temperature then with engine running cycle through gears and top off till it overflows. My question is is if I cycle through gears do the drive wheels have to spin. I would like to use ramps in front and jack rear till car is level if possible.
Also are there any cars that need the wheels to spin. I have 2 other cars which would have to be changed down the road. A 2007 A6 with what i believe is a ZF trans and a 2008 BMW X3 which I think is a GM trans but havent researched that yet. Since both are AWD I would not be able to use ramps if the wheels must spin.
