Auto-Rx Maintenance Plan With Extended Drain
Jacksonville Beach Fl
Auto-Rx Maintenance Dose with Extended Drain
The test vehicle is a 1992 Ford Explorer Sport, with a 4.0 liter single overhead cam V-6. Important to note that a cleaning and rinse with Auto-Rx was performed prior to the test.
Next, a short run on Mobil 1 Truck and SUV 5w30 was performed to establish the norm of this particular motor. This run on Mobil 1 was for only 1434 miles, but was sufficient to point out a couple issues that needed to be corrected. The analysis revealed that fuel dilution was the biggest issue and contributing to high copper readings, from bushing wear. Also, even though the air filter had been changed out only 8000 miles ago dirt ingress was an issue. Prior to starting the Auto-Rx Maintenance dose, with Pennzoil Platinum, new plugs, wires, PCV valve were installed. A new air filter was installed half way through the maintenance dose run which was for 6101 miles.
Despite the tune up parts, the motor still suffers from a fuel dilution problem, although greatly improved. When looking at the numbers bear in mind that the second run with the maintenance dose (3 fluid oz.) was run for a duration of 4.25 times the mileage as compared to the control.
The combination of Pennzoil Platinum and Auto-Rx shows exceptionally low wear metals, with the exception of copper, which is still due to fuel dilution. It is very likely, that the maintenance dose is providing addition protection of the cylinders and bearings. It is also important to note that the additive package of the Pennzoil Platinum is not compromised at all with the Auto-Rx maintenance dose, in fact may be somewhat preserved. Slightly elevated oxidation readings would indicate that the maintenance dose is doing some additional cleaning.
If not for the fuel dilution issue this oil would be very healthy after 6101 miles and would have service life left. Without a doubt Auto-Rx is fully compatible with this Group III synthetic oil
Frank,
I saw a couple other maintenance dose tests that you had performed. One being on the Saab 900, where pics showed that the maintenance dose showed further top end cleaning. The other was the March 7, 2007 ARX and Mobil Oil header, under what's new. Very good wear numbers running the maintenance dose coupled with the fact that the vehicle has a fuel dilute problem.
Get this data better organized for easy review by your visitors. The maintenance dose is a very good thing.
For an eight quart sump you might want to experiment with a larger dose that would represent the same percentage as in a smaller sump.
Larger sumps are one of the best things you can do for any engine.
ericql (what every that stands for) tell us more about your car and your driving habits. Is this one of those V8 rockets? What oil do you use?
(First name, middle and last initials (although it is a G))
It is a previous generation V8, with timing belt and much lower HP (~300). Currently it has Walmart 5w30 during an ARX rinse phase, then I will return to Rotella 5w-40 till my stash is gone.
From feedback it is beginning to look like belts are better than chains. Some modern engines that are experiencing shearing do to fuel dilution might be better off with a belt drive that never sees the engine oil.
