Auto-Rx and Acura transmission
California
After reading all the good things about Auto-Rx, I ordered some for my oil and my auto transmission on my 94 Integra. I understand the process for the oil change, but am a little confused about the flushing part for transmissions.
On the Auto-Rx site, they recommend using a T-tech flushing system to completley change out all the ATF. However, when I called a local dealership, they said that Honda/Acura recommends against using this process, but instead a "triple flush."
I just want to know what's the best process to use to flush out the transmission on my car.
quote:
Originally posted by Frank:
T-Tec is a machine that removes all contaminated transmission fluid throughout your unit and cleans torque converter, than refills with new transmission fluid. With 6 ounces only of Auto-Rx in transmission unit and driving 1000
miles it is time to drain entire transmission.
Have no idea of what comprises a "Triple Flush" from dealer ( suspect using solvent and than additional additive as part of procedure you don't need either one ) transmission fluid is basic hydraulic fluid very thin viscosity (ISO 68 )and whatever type additive package manufacture that is included with fluid. Timmy find out what is in triple flush ask if they clean torque converter and tell them no solvents or additive to be used and than see what a "Triple flush " is. After cleaning is completed using Auto-Rx just use transmission fluid of your choice.
I think the Honda/Acura automatic transmissions hold less ATF than most and a larger proportion drains from the sump drain.
I do a triple flush on a Honda. Warm the transmisson by driving, drain the transmission sump and refill, drive around the block, drain & refill, ditto, ditto.
Ken
According to the service rep, a "triple flush" consists of using 12 qts of ATF and changing the fluid 3 times. I was told by the same rep that because of the design of honda/acura transmissions, that this method was the safest way. He was saying that flushing the system might cause clogging.
They probable want it done this was as oppossed to the T-Tech..if the transmission is like my Accord...there is no filter/ screen that you can replace to get rid of any major, crap.
Exactly, there is no replaceable transmission filter on Acura transmissions.
Also, I just want to know if anyone with a honda/acura has done the T-tech flush and whether or not they had any problems.
There is no particulates to clog up anything Auto-Rx has liquified all.There is nothing that can stop up anything. A conventinal transmission flush
yes your dealer knows that there will be "pieces"
not with Auto-Rx. Either way you go you will be happy with results of cleaning and performance of your transmission.
i have a 90 integra that i ran auto-rx through the transmission and did t-tech. no issues except that i was very impressed with results. if you do t-tech, make SURE that you get the atf from the honda dealer and bring your own to the shop that does the service. none of them use genuine honda, which is the only way to go with these cars. the recommended substitute was DexII, which is practically non-existent. regardless of what anyone on the board says, DexIII is not COMPLETELY reverse compatible, specifically in these transmissions. it has been said by an ASE Master Mechanic that I wrote in to in Chgo Trib for his national column that DexIII can be used with lubegard in black bottle, but by that time, genuine honda is just as cheap, and you know it works-and works best. anyway, i had no issues with t-tech.
Sounds good. I've been using only Honda ATF since I bought the car and change it every 15K miles. I can get the fluid for about $3/qt so I don't mind chaging it often. If I bring my own fluids, should I bring 7 qts or do I need to bring more?
Hey there,
Is the triple flush recommended to get the old
stuff out of the Torque Converter ?
I ask this since I want to drain the fluid but
really don't want to mess with dropping a pan
since it would be my first time with working on
a transmission.
BTW- if I were to do the triple flush would this
cause probs with using a synthetic.
Mercon is recommended for my car.
Slade
Slade,
Your Ford holds more oil in the torque converter than a Honda, so it would take several more drains & refills to get a decent proportion of new fluid in your's.
Ken
