I have to replace the wheel bearing hub assemblies on the Dakota pickup in my signature. The new hubs do not include the spindle nuts. My spindle nuts are a one-time use only. It even says "DO NOT RE-USE" on the flange of the original nut. The new nut must be torqued to 185 ft-lbs with the wheels on the ground.
Question is, no parts store here sells the spindle nut. The local Dodge dealer parts department is open today but as usual they don't have it in stock. They have to order it, $17.10 each. I can get a nylon lock nut in the right size and thread pitch at Ace Hardware for about $6.00 and they have a bin full of them on the shelf today. Is there any real difference between an Auto Grade lock nut and a standard lock nut I buy at Ace? Don't they both heat up the nylon insert the same way when the nut is tightened and torqued down?
I would like to start and finish this job today. Thanks for any help you guys can offer.
