Hmm..Malvern ..very expensive! You pay first!
pa-sale
The weight you use should be what's recommended. The time frame that you leave it in service will be the question you need to ask. I believe that yours is an exchanged engine, so your oil temp will be around the coolant temp ..which works out rather well.
Do a UOA on your current oil and see how it survived over your usage.
5 to 59°F......10W-30, 10W-40
Above 5°F......15W-40, 15W-50, 20W-40, 20W-50
All Temps......5W-30, 5W-40, 10W-30, 10W-40[1]
All Temps......5W-50, 10W-50, 10W-60
Below 59°F......5W-30, 5W-40
5w-40 seems to fit the bill in most instances. Something like Amsoil AFL Synthetic 5W-40 European Engine Oil
