Hey guys going to pick your brain on attic ventilation. I have a gable roof with a gable fan. Now there is a huge difference when the fan is running. It is cooling the room above it significantly during the summer, but, is not cooling the rest of the attic. Here is my current gable setup if you are facing the front of the house
Gable vent-------Gable vent w/ fan--------------------------------------------End of the house
(over garage) (about 10-15 feet from the garage opening)
Now my question is would it be ok to add a gable vent at the end of the house with my current setup? Also if I did add the extra vent would I need to seal up the vent above the garage so the fan would be drawing air from the end of the house? Just thinking it may pull from the path of least resistance. Or I have also thought about sealing up what I've currently got and going with a vent on each side of the house so it would be a straight shot across the attic meaning
Gable vent on the side of the house-----------------------------------Gable vent on other side of house
Reason I ask is I can tell a huge difference with the gable fan drawing air from over the garage. I am thinking with the train of thought that it would draw more air through the attic therefor cooling the whole attic (during the summer). I have plenty of insulation so that's not the problem there, it's just that one side of the house is about 10-15 degrees hotter than the rest during the summer and I felt this was the best time of year to tackle this. My main concern is I don't want to put in too much ventillation in there and open a whole new can of worms. What do you guys think?
