Looking at a house with an attached garage. We inspected the attic over the house; all is good there. Properly vented and all. But the attached garage appears to have its attic space completely sealed up. It's a flat sheetrock ceiling on the inside with no soffit vents and no ridge vent and no gable vent. No attic door. Inspector of course recommends adding a vent of some sort.
Looking around it appears it's not actually required by code. Shingle manufacturers require it for their warranty (?), and it's definitely recommended by home builders as it's not that expensive. But it also appears to come up in a number of threads as "not that common".
Anyhow. Since I can't open it up to inspect... just how was it done? It's about 20 years old. How were they doing it back then? Yes I know, I'm looking for an educated guess. Wondering just how fast I should open it up and look for myself. Did they skip on vapor barrier on the outside, skip on insulation in the walls and ceiling, ... Just what is common on this sort of thing?
On the funny side of things, it appears they used the wrong sized garage doors. 3 inches too wide? They cut little notches on the bottoms to "fix" that. They should have put the cut materials back onto the bottom sill to prevent critter entry. Who knows whose fault that was--guy doing the framing or the guy ordering the doors.
