Bror,
Moly Bond X-200 Universal Engine Oil is a superior quality universal straight grade motor oil that has been specially formulated to meet the year round service requirement of both
heavy duty diesel and gasoline engines , especially those low emission and
older heavy duty diesel engines running on low-sulfur fuel.
Moly Bond X-200 meets and exceeds the following specifications and manufacturer’s requirements. MIL-2104G, MIL-L-46152E, API Service Classification CF/CF-2/SJ, Mack EO-K, Mack EO-K/2, Caterpillar, Cummins, Cummins NTC 400 and double NTC 400, Cummins L-10 and 14L HST, Navistar, J.I. Case, John Deere, Komatsu, Allison C-4, Detroit Diesel, MAN 270, Daimler Benz Sheet 226.0, 227.0, 228.0, Scania, and Volvo.
Micron Moly® SAE 10W-40 motor oil is a premium quality fuel efficient multi-grade motor oil that is specially formulated to reduce friction wear, increase engine efficiency and extend engine life of
gasoline powered engines .
Micron Moly® Oil SAE 10W-40 meets and exceeds the following specifications and manufacturers’ requirements: : MIL-46152E, CID A-A-52039B, API Service Classification SL, Energy Conserving, ILSAC GF-3, Ford M2C153-G, General Motors, ACEA A1-02, A2-96 Issue 2, A3-02, A5-02; Daimler Chrysler 229.1, 229.3, MS9767; JASO JIS K2215
They both are from the same base stocks with the same friction modifiers.
Hope this is not too much tech talk, but this is about the best answer I can give.
david
[ November 26, 2002, 10:00 PM: Message edited by: David ]
