1990 Ford E350 cutaway van, 27-foot motorhome, with 460 V8 and E4OD transmission. Changed transmission fluid at 74,000 miles. Existing fluid was 50% original (presumed, bought used) and 50% Mobil 1 Mercon ATF installed with filter change at 52,000 miles (when purchased). Sample analysis was afterthought and so was taken from empty 1 gallon Ice Mountain spring water jugs that I drained it into and should have been dry (but the high parameters are not exactly what you would expect in springwater if residue was on the inside of the bottle). Anyway samples were collected by draining torque converter directly into jugs and by siphoning from dipstick tube with clear plastic tubing (possible silicon source) from hardware. So the sample results may be suspect, but might as well post them. BTW, the transmission performs just fine and was refilled with M1. There are about 3 to 4 quarts still in there of the old fluid (total capacity 16 qts). Only thing I can do now is forget it and/or pull another sample (by plastic tube down dipstick tube) sometime after I rack up 10,000 or so miles.
Aluminum 10
Chromium 2
Copper 181
Iron 77
Lead 87 abnormal
Tin 12
Silicon 31 abnormal
Potassium 5
Sodium 18
Moly 0
Water less than 0.1
Oxidation 7.4
Gycol ND
Comments:
Suspect clutch/disc pack damage.
Silicon level (dirt/seal material) higher than normal.
Moderate concentration of water present.
Resample at next service interval to monitor.
Drain oil from unit if not already done.
Aluminum 10
Chromium 2
Copper 181
Iron 77
Lead 87 abnormal
Tin 12
Silicon 31 abnormal
Potassium 5
Sodium 18
Moly 0
Water less than 0.1
Oxidation 7.4
Gycol ND
Comments:
