meborder
Originally Posted By: meep
pop-ups are easy to pull. it's not the weight as much as it is the frontal area... which they have very little of. On top of that, it's light. And if you are paying attention to the speed ratings of the trailer tires, you'll be under 65. therefore, not critical.
OTOH, 60k is enough miles in my book to warrant a change, so I'd plan for it at some point.
I've seen a good number of Expi's on factory fill at 150k driving fine, so I suspect for daily driving they are overbuilt.
as an aside, and only because you mentioned it, but completely off topic ...
I was actually quite mindful of the speed rating on my trailer tires. they were Kenda LoadStar ST145r12 LRE (10ply) which replaced the LRD (8ply) orignals that blew out on the road.
the original tires ad a 75mph speed rating (Service index followed by the letter "L" indicating the speed rating of 75). one of these blew out on a hot day at 65mph. in all honesty, I'm thinking my father in law didn't check the pressure, and that's whyit failed.
the Kenda LoadStars are advertised as a 65mph speed rated tire (according to etrailer). I ran them at 70mph, but brough my IR gun along to keep an eye on tire and bearing temps. on the road, the tires, rims, and bearings were always 113-117°F, with the ambient temp in the low to mid 90's. checking the pavement next to the tire (when stopped) the tires were running essentially the same as the pavement - within a few degrees anyway. this settled my mind about exceeding the speed rating.
I'm guessing by upgrading to the LR-E tires, I bought some headroom with regard to speed with the increased load carrying capacity of the tire. with the 10 ply rating, the tires weren't so near to the max load as were the 8 ply tires.
I have no reservations running those tires at 70mph. I considered upping to 75, but with two kids in the back and ambient temps in the low 100's (104 at wasta, to be exact), I didn't feel like pushing my luck anymore than I felt I already was.
nothing to do with transmissions, but interesting, I thought ... and since you brought it up....
