I use MMO only in my gas. A few oz's per tank. So shortly I'll pull my plugs a give it a looksee, if there's much carbon built up. I have freed up a stuck Mercury outboard motor by dumping Liquid wrench in the cyls.It took me a week of pouring some in the cyls each day, and tapping on the flywheel to get it spinning.This was 25+ years ago and you could get liquid wrench in 1 gallon cans. A stuck ring, or a broken ring, or a hole burned in the piston will give you low compression.,,
