ATF recommendation for 2002 buick century
Northern Kentucky
Looking for a fluid recommendation for a 2002 buick century with the 3.1 v6. Have heard of using OEM fluid, maxlife, and have considered Mobil 1. Any thoughts?
Also does anyone know the pan size and total system capacity on these transmissions?
My 2002 car uses Maxlife and performs very well. I don't know how much difference the fluid actually makes, I think the condition of the transmission when it's changed makes more of a difference. Have heard good things about a Lucas additive, though.
Should be a 4T65 with a capacity of 12 quarts of ATF. Pan size is about 5-6 quarts. Maxlife does very well in those older GM transmissions.
I have a 2001 Grand Prix with the same trans.
Here is my history and what I've done.
Bought new.
30k I did a pan drop and filter change with M1 Dex IIIh
60k I did a pan drop and filter change with M1 Dex IIIh
90k I did a used oil analysis, it looked good. Flushed with Dex VI after the pan drop.
120k I did a pan drop and filter change with Dex VI Installed a shift kit to fix occasional hard shifting issue.
150k I did a pan drop and filter change with Dex VI
180k I did a used oil analysis, looked even better than at 90k. I then flushed it with Redline D4 after the pan drop.
Around this time I was getting erratic shifting and torque converter lock-up. It was not better with the D4 and eventually got worse. Changed out the MAF and all is good now with 193k miles.
You get about 8 quarts of fluid out with a pan drop and filter change, a pretty large % of the fluid capacity. I honestly think that 30k interval pan drops and filter changes are adequate. I like to experiment a little which is why I have D4 in there now but I'd just recommend Dex VI of any brand.
My previous car was an older GP a 4T60E (vs a 4T65E) and I did 30k pan drops and filter changes its entire life (212k miles and 13 years when I got rid of it) and all I ever used was name brand Dex III, nothing synthetic. It was a flawless trans the entire time.
OCI plan?
Any normal interval would be easily serviced by a good house brand Dex/Merc alternative. I believe DEX III was the FF.
Originally Posted By: 901Memphis
So if i went with maxlife i would just get the DEX/MERC or does the DEX 6 make any difference?
The difference is that some so called 'DEX MERC' product could be literally anything, however a genuine DEXRON branded product is by definition tested, approved and controlled.
So would Dexron VI be a good choice then? Also is it bad to mix DEX/MERC with Dexron 6?
I saw a couple brands available, Valvoline, Pennzoil and Castrol both make a DEX VI. Are they equal?
After getting a better look at the condition of the fluid i think i might put some DEX/MERC in there to get all the old junk out then switch to DEX 6.
The old fluid looks pretty bad though. I'd hate to send it in for UOA. Could possibly be almost 100k miles on this fluid.
Originally Posted By: johnsmellsalot
Dexron VI is better than Dexron III. It is backwards compatible too. Don't use additives.
Yes, yes and yes.
I think its been in for 100k. Going to need to get it out soon.
YES!
