Hello All,
I recently asked a question about my transmission in my 2013 kia forte with 13,000 miles being a life time fill. Most of you said what i thought you would, and how I felt aswell.. that life time fill means the life of the transmission, and NOT the life of the car.
So.. I have been contemplating on how to handle this. The process to do the drain and refill on this transmission is quiet in depth and difficult, and requires a scan too.
That being said.. If I just drained as much out of the transmission fluid AS possible, and measured it out, then put exactly that much fresh transmission fluid back in.. could this cause issues? I know the old transmission fluid will have wear particles and probably have broken down some, So to the eye what looks like the same volume may actually not be?(if that makes sense.)
I want to avoid taking it to the dealer for the ATF changes as I have heard they are quiet expensive. 2-300 dollars using the oem fluid.
Also the Kia requires a SP-IV specced fluid, the hyundai version is obtainable from amazon at 17-20 dollars a quart.
But I did notice that valvoline offers Valvoline Import Multi-Vehicle Automatic Transmission Fluid that meets the specs of Kia's SP-IV. Would this ATF be ok, or should I try to stick with OEM?
http://www.valvoline.com/products/brands/valvoline/automatic-transmission-fluid/137
Thanks!
Thanks!
