What type of transmission cooler, well the best 1 is a B&M Transmission Cooler and I will tell you why, it has something built into the cooler that when the transmission fluid is cold it bypasses the cooler so you will not over cool the trans fluid, it is not a tube and fin design but a stacked plate design that is very efficient, make sure you mount it in front of the radiator, B&M even makes 1 with a fan and the fan only comes on when the fluid reaches 175 degrees, you can get these coolers either through Jegs or Summit Racing, these are excellent coolers, if you mount it in front of the radiator make sure you do not mount it right on the radiator, I had 1 that I mounted in front using some metal strips it was 6 inches in front of the radiator, unfortunately a few years ago I hit a deer and it was busted but the radiator was fine and the cooler had a pin hole leak so I had too get rid of it, I made it home but without it there I would have busted the radiator. Even with a cooler synthetic transmission fluid is a must, the best choices are Amsoil, then Redline and finally Mobil 1.
