I'm planning on doing a ATF change in the early spring. I'm going to have a professional do it. I had it done with 60K on the OD....my vehicle now has 94K.
My question is....should I go to my local Ford dealership to do the work (which I did previously)...or let an independent repair shop do it? Do you think there is a cost differental?
My vehicle is spec'ed for Mercon V....but I've decided to use Amsoil ATF (which I'll supply)... and have a Magnafine filter installed.
Would appreciate your suggestions and experience.
__________________________________________
2003 Ford Focus (2.3L Duratec) / 94K
Mobil 1 Extended Performance 5w20/ Mobil 1 Extended Performance Filter/ OCI: 1 Yr. or 10K +/-
