ATF change interval in a Saab 9-5
Viña del Mar, CHILE
Hi there!
I've a 2004 Saab 9-5 that comes with the Aisin transmission and it uses the toyota t-iv ATF.
I changed the fluid for the first time at 50k miles. It came out pretty dark, but without a burn smell. I changed it again at 62k miles and it was also dark, with a redish dark brown color.
I was planning in changing the fluid every 25k miles, but after seeing how the fluid came out in my second change, I'm considering now changing it every 12k miles until I see a cleaner looking fluid coming out.
Considering that every change renews around half the fluid in the gearbox, what would you do?
Thanks in advance
If you did just a drain & fill, then 12k intervals sound ok. For full fluid exchanges, like via cooler lines, 30k is always a safe interval.
Regarding ATF color, I would not worry about it much, if the transmission is shifting normally and the fluid doesn't smell burned.
My Mazda 3 is the same way in that regard, while the fluid stays nice and red on the dipstick, when drained it is dark and not transparent (due to clutch material I guess), I never noticed shifting problems, so it's the nature of the beast I guess
Now that you say that, it makes sense. I've also found that the fluid in the dipstick looks normal, just before I drain it. Maybe is just the way it works.
I'll try 25k miles for the next drain and see how it goes. It's not that long of interval either.
Do yourself a favor and do a drain/refill every 12-15,000 miles if using a non-synthetic ATF. Should be able to at least double the interval if you use synthetic (assuming that you've done several drain/refill operations when first going to synthetic).
