Is ATF+3 a Group-I fluid? How about the ATF+4...I think maybe a Group-II/III blend. What is Mercon-V? I have a Stratus that needs an ATF change. It calls for ATF+3, but a trans shop here said Mercon-V with the Red bottle of Lubeguard works best, as it is a synthetic blend. He recommended Castrol ATF. I thought ATF+3 was a synthetic blend by nature, but I may be wrong. The car gets driven hard at times and sees higher speeds at higher rpm's for extended periods. That is why I am interested in a synthetic blend ATF. I checked on getting ATF+4 from three dealers...but it is between $9-12/qt!! I would like the redline C+ ATF, as suggested from searching posts, but again it is $8.50/qt here. I do like the prices of the Castrol Mercon-V at $3.27/qt, and ATF+3 is $1.98(store brand)-$3.47 name brand. My last Stratus had MaxLife ATF installed at a ValvIOC...didn't work well. It shifted erratic, grabbed gears too soon, etc. I have been a big 'only use' ATF+3 or +4 since that experience. But a very respected trans shop said the Mercon-V syn blend has done exceptional in chrysler applications, especially in dodge transmissions used for towing. I installed Lucas Trans additive in the last Stratus, and it seemed to work well. Fluid temps were ~40'F cooler! Any thoughts? Advice please?
