As per many owner's manuals, oil should be drain when it is warm (not hot). It has nothing to do with climate, oil type, etc....
Therefore, run the engine a few minutes to warm up the oil and then drain. What are the reasons?
1. Allow oil to fully circulate around the engine parts and "hold contaminants" in suspension (that would have otherwise sedimented overnight...either on engine parts or bottom of pan).
2. Warm oil flows better allowing quicker draining and a more proficient oil change without getting burned! Overnight isn't necessary...allow to drain until drops are less than 1/sec...
As far as any addatives...shouldn't be required with good quality oils...oils have their own detergents, emulsifiers, etc....any remnants thereof may clash with the new oil and even render their addative packages less effective not to mention possible engine damage with long term use...
