Asian Blue Coolant
I heard in an earlier thread few months ago that Supertech coolant is made by Peak and that Supertech Asian Blue is Peak in a Supertech jug.
Does anyone know for sure who makes Supertech Asian Blue?
If it's Peak, count me in for Supertech. It's it's Prestone, count me out for Supertech.
Peak is available in a jugs of concentrate or 50/50. Supertech is available only in jugs of 50/50.
I like to put in concentrate after flushing system with distilled water. For top offs I like to put in 50/50.
I highly doubt it's Prestone when WalMart is also the #1 seller of Prestone. Rumor I heard was it's Reochem which I have used in the past. The label on Reochem Asian Blue is nearly identical to OEM Nissan.
I guess who makes Supertech doesn't matter. What I should have asked is Does Supertech contain 2EHA?
^^^^ Asked and answered with documentation two months ago.
The current version of the SuperTech Asian Blue 50/50% Extended Life coolant is made by Old World Industries (i.e., PEAK). I doubt it is any different from the PEAK packaged product in the blue bottle. Here is the SDS for the current SuperTech Asian Blue which does not list 2EHA as an ingredient. It is notable that the SuperTech yellow AMAM coolant does list 2EHA in the SDS.
SuperTech Asian Blue SDS
Interesting. I bought 1 gallon of Peak Asian Blue concentrate, but if I need a gallon of 50/50 in future I'll buy Supertec Asian Blue because it's ridiculously low cost and you said it's made by Peak and has no 2EHA. Sold!
Thanks for resfreshing my memory on that. My memory isn't the best. Also some posts by others in this thread made me wonder. Thank you!
Note: I've been having some memory issues, which might be old age, or might be a side effect of my blood pressure med which makes me groggy. Hopefully it's nothing more serious or I'll have to change my screen name to Drooling-Idiot.
AI says,
Yes, Super Tech OE Blue Antifreeze Prediluted 50/50 is formulated with 2-Ethylhexanoic acid (2-EHA), also known as Sodium 2-Ethyl Hexanoate.
2-EHA functions as a corrosion inhibitor in coolants, helping to protect engine components from rust and degradation. However, some sources suggest that 2-EHA can potentially damage silicone components found in some engine models, particularly in heavy-duty applications where silicone seals are more common.
YMMV
Walmart uses different suppliers based on region. It could be Peak, Prestone, Recochem, or possibly someone else :sneaky:
I'm not disagreeing nor arguing with you or Nukeman. I respect and appreciate both of you for your knowledge and helpfulness. Maybe I'm missing something, but I have the following concerns/confusions and questions about Supertech.
How can Supertech Asian Blue have one accurate data sheet (see post 23 by Nukeman) if a different manufacturer supplies each region?
Wouldn't the formulation vary per manufacturer, and therefore vary per region? If so, could that mean Supertech has no EHA in some regions, but has 2EHA in other regions?
AI says,
YMMV
I don't know if that ^ info is correct, but I do know that AI is an unrealiable source of info.
I have seen multiple instances of Google AI giving incorrect info about topics that I'm an expert on. I would not rely on AI. It's not nearly as smart or as knowledgeable human experts. I'm not an expert on coolants, but I am an IT expert/professional.
I've seen Google AI be wrong about car maintenancs topics that I already for sure knew the answers to. I've seen Google AI be wrong about IT topics many times.
I don’t see how the SDS for Preston helps. It could contain no 2EHA whatsoever or a significant amount based on that sheet.
Correct. You can't know if Prestone has 2EHA or how much.
Not knowing is 1 reason not to use it (because Prestone is being evasive on the topic).
The fact that it might (and likely does) have 2EHA is a 2nd reason not to use it.
Like Nancy Reagon used to tell kids... "Just say no to Prestone".
That Prestone SDS is dated 1/13/20. The one I posted for the Old World Industries (AKA: PEAK) was dated 5/19/23.
I suspect that WalMart SuperTech changed AF supplier contracts between those dates since the bottle style changed in that timeframe (see below).
Old ST Asian Blue Current ST Asian Blue
If Supertech Asian Blue is now/currently manufactured by Peak (for Walmarts in all regions of USA) that is a good thing that would mean there's is currently no 2EHA in Supertech Asian Blue in 2025.
However, if Walmart changes suppliers in future, I won't know about it because I won't be keeping track of this topic in future. So in future, I won't know if Supertech AB has 2EHA.
So in future I won't be using Supertech AB because I won't trust it, even if it is currently fine.
That's a resolution of the Supertech AB topic for me. If others want to continue discussing it, that's fine. 👍
For me it's Peak or Zerex. I'll get whichever is lower cost or more convenient to obtain. In my area, NAPA sells Peak. Oreilly sells Zerex. I think Walmart sells both. I'm not aware of any local stores selling Pentafrost, but if they did, I'd be willing to use it if price was right.
NAPA & Walmart are 1.5 miles from my home. Oreilly is ½ mile. I don't walk very well, but my mobility scooter can go sprinting speed for 5 to 6 miles. So Oreilly is an easy trip in good weather. The other 2 are doable.
Normally Walmart has best prices, but sometimes autostores have sales.
Two months ago I bought Peak AB concentrate from NAPA because it was on sale. It was put into an 03 Honda CR-V to refill radiator after system was flushed with distilled water. For one of my neighbors who takes care of me part time.
Recently I bought Zerex AB from Oreilly to be used in an 11 Hyundai Elantra. For my other neighbor who takes care of me part time.
I got cold feet when realized the Zerex jug says 5 years while Peak says 10. However, that's no longer a concern thanks to Slacktide explaining to me that the maintenance schedule will still be the normal time specified in the car's manual.
My questions and concerns have been well addressed by SC-Maintenance, Slacktide, Nukeman and others. Thank you very much!
I also want to thank Trav and others for the excellent coolant related advice in an earlier thread regarding 2EHA in regard to universal coolant for my Buick.
I've known the basics about oil for years, but I didn't know much about coolant. What little I did know about coolant was outdated. I started learning about modern coolant a few months ago. First universal coolant vs Dexcool for my Buick (I'm now using Peak Titanium in my Buick). Later I started learning about Asian Blue for Honda and now Hyundai.
Thanks everyone for the education! 😀👍
Zerex is on sale this month at Napa.
The 50/50 premix is 17.99
The concentrate is 20.99
Really? Those are good prices. I didn't see Zerex at my local NAPA last time. I did see Peak at local NAPA on sale in June and bought a jug.
My local Oreilly has Zerex, but not Peak. I bought a jug of Zerex from Oreilly in July. Unfortuneately it was not on sale.
Really? Those are good prices, especially for Peak. I didn't see Zerex at my local NAPA last time. I did see Peak at local NAPA on sale though and bought a jug.
My local Oreilly has Zerex, but not Peak. I bought a jug of Zerex from Oreilly.
If your local Napa doesn't have it in stick, they can order it for you :)
