Are these headlight housings too far gone to polish?
North Carolina
This is with the headlights on, showing vertical lines, are these cracks? No moisture in them. It was raining when I took the photo.
What year? The top of my wife's 2015 Subaru Outback looked similar but without the micro cracks. I had been applying Meguiar's PlastX and Meguiars Headlight Protection 2 times per year as it doesn't last long as the headlights age.
I recently used Cerakote's system to clean and seal the lenses ($16). We'll see how long it lasts.
I've used Magic Eraser pads and gotten results very similar to the kits that cost $35.00+. Every 3-4 months while the oil is draining, I clean the headlights. Easier and cheaper than replacing the whole assembly.
13 Elantra. If it cleans up, napa has a 2k mixing spray can of clear to coat them with.
I'm going to pull them off to try it.
It is worth a shot but you have to sand them really well. Use a kit with sandpaper not just the polish kits to get the most improvement and better yet the kits with the drill adapters so you can sand much easier and more effectively.
Are there any roloc discs i can use with a die grinder ?
Don't uses them, that will ruin the lens. Remove the light and use a orbital sander with #400, #800, #2000 and finish with a 3000 or 5000 Trizact disc, use all the disc with water then polish the lens with a buffer and rubbing compound then a light polishing compound.
You can use 2K urethane clear or one of the kits for the final coating, the one from Sylvania seems to work well enough and is much easier.
Thank you Trav!
Learned here, my method is a bit more barbaric but I’ve done it to at least 20 cars if not more with the worst ones that come in to our ministry.
- WET sand it with 440 grit (you’ll need this with your yellowed lens, perhaps even start for a minute with 220 grit)
- Hand polish with XXX fine steel wool, light pressure wet and smooth
- Dry it, check. Redo any above if needed. Should be a consistent white cloud
- Mask the area more than you should and throw rags over the fenders
- 1 medium coat with U-Pol clear, count 30 seconds
- 1 light coat
Notes - U-pol goes on with orange peel and then levels out. You need to practice this on a cheap picture frame first to get a feel for it. If it runs, and it can quickly, it’s hard to sand down, though really isn’t the worst.
U-Pol doesn’t yellow. You’ll do this once and it lasts years.
My son’s VW headlights were a little bit worse than the ones you posted. I took it to Sam’s Club and they did an unbelievable job. They came out looking like new. 🙂
