This is with the headlights on, showing vertical lines, are these cracks? No moisture in them. It was raining when I took the photo.
13 Elantra. If it cleans up, napa has a 2k mixing spray can of clear to coat them with.What year? The top of my wife's 2015 Subaru Outback looked similar but without the micro cracks. I had been applying Meguiar's PlastX and Meguiars Headlight Protection 2 times per year as it doesn't last long as the headlights age.
I recently used Cerakote's system to clean and seal the lenses ($16). We'll see how long it lasts.
Don't uses them, that will ruin the lens. Remove the light and use a orbital sander with #400, #800, #2000 and finish with a 3000 or 5000 Trizact disc, use all the disc with water then polish the lens with a buffer and rubbing compound then a light polishing compound.Are there any roloc discs i can use with a die grinder ?
Thank you Trav!Don't uses them, that will ruin the lens. Remove the light and use a orbital sander with #400, #800, #2000 and finish with a 3000 or 5000 Trizact disc, use all the disc with water then polish the lens with a buffer and rubbing compound then a light polishing compound.
You can use 2K urethane clear or one of the kits for the final coating, the one from Sylvania seems to work well enough and is much easier.
