quote:
they just didn't last very long (less than 30k and the replacements were the same way). i was very disappointed.
Seotaji, just a thought, were they 80/82 series twin tube dampers, or 30 series mono-tube ? Bottom line is you should get much more than 30 000 miles out of either of them.
You've really taken me by surprise with your experience there. I'd be awfully unhappy as well, and doing a fair bit of jumping up and down and yelling at the importer.
Years ago they did come poorly finished in terms of paint and presentation, but they made up for that in the quality of their internals. One area they are still slack in is packaging of spares. I've had valve assemblies turn up, still sealed in their little plastic packet with surface rust on them ! Complete shocks have always been immaculate internally.
I must admit I haven't used any car Koni's for a number of years, but their 82 series 4WD 'Specials', now known as 'Heavy Track' are excellent build quality, being far superior to say, a Ranch RS 9000 in strength and longetivity and valving. (although I'm unhappy with some recent Nissan ones and will be re-valving them)
I've fitted them to a number of road and off road vehicles over the last twenty years, and they've always lasted until the vehicle was sold.
We also used them on open wheel race cars, particularly the older 8212 series alongside Penske, Bilstein and Ohlins and they worked in certain specific applications very well.
I've also re-built/re-valved a few recently to suit a specific application, which is something you can only do with Bilsteins or a twin tube Koni of the mass market shocks. The mono tube Koni's aren't revalveable/re-buildable, although you can externally adjust the rebound valving. When they assemble the damper, the top of the body is crimped in to hold the top bush/seal assembly. On the twin tube it is threaded and screwed, and Bilstein use a circlip.
They actually have the reputation here in Australia as being the shock absorber you use if you want them to last and not blow seals when you load your 4WD up to travel through the outback.
