edyvw
$50 site donor 2025
ATE, Textar, Zimmerman, Pagid.Serious question. When I need to replace them on my E350 AMG pkg, what would be the best brand to use other than oem?
But by far my favorite, and quality-wise, most consistent is ATE.
It's more than just better cooling design. The lighter two-piece design itself allows for better heat dissipation.
Mic drop, if I've seen one.... ... ...
Slotted rotors will or were designed to keep the brake pad face clean and dissipate heat. I'm sure in some instances they do help. The biggest reason that cross drilled rotors were used was lightness and the fact that alot of racing brake pads had outgassing when hot causing pad float. This isn't really an issue any longer.Just wondering what's the opinion on drilled and slotted rotors for normal street use and some rv towing ....... 2016 ram. 1500
Mine are drilled and slotted oem MB. I notice the holes get clogged with pad dust. Don't know if it's self cleaning..Slotted rotors will or were designed to keep the brake pad face clean and dissipate heat. I'm sure in some instances they do help. The biggest reason that cross drilled rotors were used was lightness and the fact that alot of racing brake pads had outgassing when hot causing pad float. This isn't really an issue any longer.
Brembo?ATE, Textar, Zimmerman, Pagid.
While still expensive carbon ceramic rotors might be a possibility for some makes and models now, not just high dollar exotic cars.I think you might be better off just buying performance/heavy duty pads instead. Take a look at performance cars sold new like 400Z and Supra etc, they have big brakes but the rotors are plain. So it seems like slotted/drilled rotors are kinda not necessary for hard driving, but quality rotors and pads are...
They are OK when it comes to regular aftermarket stuff. Still, prefer others.Brembo?
Since you're towing and moving heavy loads, brake pad compound is gonna be more important here, some brands sell severe duty semi-metallic pads for your application.Just wondering what's the opinion on drilled and slotted rotors for normal street use and some rv towing ....... 2016 ram. 1500
Slots>drilled but neither are necessary here. Save your money.Just wondering what's the opinion on drilled and slotted rotors for normal street use and some rv towing ....... 2016 ram. 1500
