Anywhere to buy "bulk" distilled water?
Farmersville, Ohio
Need to do a thorough flush and refill on a tractor that holds 10 gallons of coolant. Instead of trying to buy 20+ gallon jugs of distilled water i'm curious if anybody has found a place to buy 5 or 10 gallon jugs. Or even 2.5 gallon jugs would be a lot easier to deal with.
Rural King sells it in cases containing four - 1 gallon jugs. It would make it a little easier, to be able to get it all in 5 boxes.
It'll be easier to handle several 1 gallon jugs vs 1, 83 pound container of water. What will make it easier is a proper funnel assuming you have room to pour the water. A cooling system filler would work, too.
Hopkins 10703
My local Food Lion has 2.5 and 5 gallon jugs of distilled.
The 2.5 has a spout built in and it is very convenient for diluting chemicals.
If you were closer I would give you 20gal of RO water.. but the 3.25hour drive each way would kill that.
Buy or make a still and you can have all the steam water you need. Then, go in business selling it as a side hustle.
You only need to use distilled water to mix with full strength AF/coolant once everything is flushed. So 5 gallons of distilled water to mix with 5 gallons of AF/coolant. Whole Foods I shop for certain things at has gallons of distilled water for .99/gal.
Coolant changes using a distilled final rinse and distilled in the 50:50 mix yield clear coolant of whatever color.
Our region's well water is called "liquid rock".
An unused toilet will have a coating in the bowl from sitting overnight.
When I'm scolded for overkill it comes from someone who doesn't want to spend Their coolant is cloudy and slime forms quickly in the reservoir.
I suppose it's a question of degree.
I would do the flush with drinkable tap water and if you like use distilled water with your anitfreeze. For instance, GM asks only for potable water when mixing antifreeze. The rest is Bitog overkill.
Drinkable tap water has minerals and possibly chlorine. If you flush with that, some will stay in the block as it does not all drain out. Only use water without minerals for filling and flushing.
