BigCahuna, HDEOs have a potent detergent and dispersant package ... good for cleaning old gunk and holding in suspension. I'd change it every 4-6 hours until the oil cleans up.
Chewy781, the heavier weight oil is probably putting a bit more load on the engine ... and that is causing the more noticeable vibration (not greater compression). In your case (or the case of VERY new OPE) I might go with an XW-30 oil ... but watch it like a hawk for signs of consumption. I've never said 15w40 is a 100% solution for all OPE. But for most, I'd say it'll provide as-good-or-better service than a straight 30 or XW-30.
JustinH, true, I've heard all kinds of stories of OPE engines surviving criminal levels of neglect. I believe most of them and have even some examples first hand. But I've gotten a lot more used engines that smoke heavily, burn oil, etc ... from that kind of abuse ... and don't want that kind of poor (embarrassing) performance from something I had to walk behind ... especially when proper, basic maintenance takes just a couple hours per year.
So Meep, what do you run in your gensets? If oil temps are rarely over 150F, I probably wouldn't run anything thicker than a XW-30 ... but I'd pick one with a stout additive package.
Doitmyself, I'm not sure that commercial equipment is run under any more demanding conditions ... but they are typically run at greater frequency. I'm thinking of the guys that have commercial mowing businesses and run their mowers 40-50 hours per week. We've had some of these guys on this site talking about the equipment and business habits over the years.
Some of the same issues driving a simplistic recommendation for a straight 30 or synthetic XW-30 apply to commercial equipment, too. When you're in business to get work done and make a profit, you want maintenance to be fast/simple/convenient. You don't want to have to carry exotic lubricants, etc ... So, Kohler and Kawasaki would rather recommend common, easy to find lubricants that will work well enough, for the most part, most of the time, in most applications ... as opposed to something like a 5W-40 which might not be available everywhere ... or a 15w40 which may not be ideal for cooler conditions.
I would like to think they would offer a chart covering temps from well below zero through 100+F but they don't ... at least not any more. They don't want the engine to last forever ... just the expected 500, 1,000, 2,000 hours, etc ...
