Anyone use pads on their foor jacks?
New Orleans La
I've never used on. Had a jack slip on me yesterday as there wasn't much lift on.
Somewhat related... my jack has a 13/16" hole that the rotating pad fits-in to. I also have a 4"wideflange (I beam) section that spans rocker panel to rocker panel, with a short length of cold-rolled 13/16" round barstock welded to the flange of the I beam, midspan. This allows me to put the beam onto the jack and lift one end of the car without worrying about the I beam tumbling-off the jack.
I use one on unibody vehicles I lift by the pinch weld, especially if there's little left of it due to rust... IF I can't find a better spot which I try to.
It all depends on what point you're trying to jack.
Even if you don't have those issues, I've seldom found cases where it was worse to use a puck, makes me wonder why more jack manufacturers don't include them, but of course there's that slight added cost.
I used to use a hockey puck. But my BMW slipped off it one day (there was a bit of oil on the front lift point).
Now I use an octagonal chunk of 2" thick softwood (made from a 2" X 4"). It fits inside the round receptacle on the jack. Inexpensive. The lift point on the car indents the wooden block..
[You orient it so the lift point crosses the grain. Otherwise the chunk might split and the vehicle could potentially drop that 2".]
Could make it out of 3/4" plywood. No concern about splitting then.
I've had jack pads on my shopping list but have never gotten around to actually buying them, after cutting a portion off a scrap 2x4 on hand, which also helps distribute the force over a greater area of the subframe lift point. Since it is starting to crumble after many years, last time at the home center, picked up a replacement off the cull/scrap pile for free. Perfect length as well.
Yes I use them on my floor jacks and jack stands....a hockey puck will work also...for the pinch weld on the side I cut a groove in the puck to fit the pinch weld..
A 2x4 block of wood works for me. I like to spread the load out as much as possible. I will use a hockey puck if the 2x4 is too big. I rarely, if ever, just use the bare jack.
My 2 heavier capacity jacks have rubber pads. My smaller one does not. I like to use the rubber pads to prevent paint damage on the point of lift.
Just my $0.02
I took a blue harbor freight caster an cut a pinch weld slot in it. Works like the hockey puck idea as both are made of similar material and are about the same size. Mississippi doesn't have a lot of hockey pucks even though we've had pro teams.
I have the one at bottom of your post. It fits on the HF Daytona jack, but does not "lock in". It just kind of sits on top of the saddle. I find myself constantly checking to ensure the pad did not move and I'm still on the center of the saddle.
I bought some of the newer Harbor Freight- Daytona jack stands.. the ones with a circular support pad and circular feet.. I ended up getting some of those hockey-puck supports for the pinch weld area.. Man! I should've gotten those long ago! love them.. yup have the hockey-puck pad on top of the circular pad.
and love both the hockey pucks and these new jack stands, nice and stable.. the height is awesome!
