Originally Posted By: Chuckinator
Originally Posted By: mrsilv04
Originally Posted By: Dallas69
I have moved on from Pur as my cheap filter choice
There are way too many others out there that do work right
Here's my new choice at $1.99 each. To me, it is a reincarnation of the original SuperTech filter.
http://www.bobistheoilguy.com/forums/ubb..._cu#Post3543143
I would never put a Chinese filter on my vehicle. Even if it was free. I rely on my truck too much, and for something as inexpensive as an oil filter there's no reason to use something cheap. Yes I know that some aftermarket and oem parts are made in prc but I will avoid it if I can
The problem is, it is a solidly built filter. Purolator could build the Classic filter this way, but for some reason... they won't.
Another pleat or two would likely make the tearing problem go away. The question is, will Purolator invest a few extra pennies in each filter for a couple of more pleats to make it happen? I know that's a killer for their bottom line. A few extra pleats per filter, times however many hundreds of thousands of filters, equals some real money.
They're trying to build a filter with as little filter material as possible, and it appears that they've found their "breaking point".
The other issue is the can on the Chinese filter is feels like it is a good 50% thicker than the Classic or the Pure One. The can on a Pure One would fail before one on this $1.99 Chinese one would.
