I just put all new front struts and rear replacement auto leveling air shocks on my 2004 Buick Lesabre and got an alignment. The tires are pretty new about 7,000 miles on them.
See the pic for the alignment specs. The rear camber is too negative so I am going to put in metal camber plates. They do 1/4 degree increments.
With rear camber at -0.9 degree at both left and right I would like to use either 1/2 or 3/4 degreee plates. They would put me at -0.4 or -0.15 deg. I am torn between the two but going for the lower camber spec might be better because as the shocks wear out and the car sags the rear will gain negative camber.
But then the toe in the rear is 0.09 and 0.05 degrees. Is there some way I should factor that into my camber plate judgement? As in, maybe adjusting the toe also affects camber in some way?
