Originally Posted By: mrsilv04
What's the story on the rebuilt title?
They said the rear ended a truck. Not sure on the exact extend of the damage.
Originally Posted By: MrCritical
If you have a "reliable" Eclipse, better call the Guiness Book of Records. You may have the only one.
The engines are super easy on oil (check the used oil analysis on here) and this one is a 5 speed with 179,000 miles on the original clutch and transmission. Only had the timing belt and water pump replaced. Serpentine belts, tires, brakes, and oil changes. Just maintenance from 125k until almost 190k. Doesn't smoke, leak, or anything. I did have to put a valve cover gasket on it. Everything looked beautiful at 170-175k when I did it. Most reliable car I've seen.
BMW would disagree with you on the GM transmissions. They use them in their cars quite often.
They use them, but BMW owners would agree with me.
Either way, it doesn't matter. I test drove that Firebird, and I kicked it from 10mph and at 3500-4000RPM, it started hesitating and jumping. Did it in 2nd gear, also, just not as bad. That was an 3 hours wasted. It idled fine, don't know if it was the plugs or plug wires. Coulda been a clogged fuel filter. Could have been in the torque converter (kinda reminded me of bad torque converter shudder).
Said no and headed over an hour back home. What a wasted trip. Sorry, I know GM has made good set ups. Like back in the day, get a 350 in a tough truck with a TH400, and you'll have a good, tough truck. But I'm a Ford man now because of my experiences and working in a garage for a few years. We worked on all vehicles, and I saw what came in the most. I figured the car would at least drive flawless with only 50k something miles on it... but me and GM have NEVER had good luck.
I don't drive my vehicles like I stole them, but I do wind them out daily, just not all the time. I use lots of engine braking (I always have manuals, have owned a couple autos), and all my Ford's have taken everything I've thrown at them (or threw in them and hooked behind them, for that matter).
Some of you guys are saying they make them 200k and more. From what I've seen, I just find it very hard to believe. Not saying you are making it up, ya'll are just telling me experiences... but man, I think they were nothing but problems. I think with a cooler installed, it helps their lifespan. But really, all of the GM pre-2000 or 2002 transmissions were junk. RWD and FWD ones. Never seen so many with problems.
But yeah, like I said, doesn't matter now.
