The gas gauge in the PA has begun to act wonky. I fill up, and the needle doesn't even move until I've clocked about 160 miles. Then it still lags, instead of being approximately correct as it used to.
This behavior started not long after I used MMO in the tank for two or three fillups -- not more than the recommended dose, but it was the first time I'd used the stuff more than occasionally. My gas mileage appeared to go up, but the gas gauge went coo-coo for Cocoa Puffs.
I plan to run the tank down to E, refill, and if necessary pop some Techron in it. If that doesn't work, well, there's the gallons consumed readout on the Driver Information Center (which is always 10% low, but I know about that and correct for it).
