Anybody know the Alero oil plug torque specs?
Cleveland
Doing an oil change for my friend this weekend and want to know if anybody has the torque specs for the oil plug? It's a 2002, 4 cylinder model.
I can't seem to find them anywhere online. I know you can easily do it without torquing, but if I can torque it, I will. I would guess around 18ft/lbs?
Appreciate the help!
Yeah, that's what I figure as well. Ill probably go to 20 ft lbs, right in the middle! haha
And its a 2004*, not a 2002 like I said above if anybody should have the right specs who may read this.
Are you kidding me? You use a torque wrench on a drain plug? I am doubting it has an offical torque spec. but if it does it would probably not be inth ft-lbs but in in-lbs or newtons!
It's probably a good idea John for people who aren't used to torquing by feel.
I normally don't and have yet to do so, but I just got my nifty torque wrench and want to put it to good use other then rotating tires... So why not!
And it IS in ft/lbs, not in/lbs.
You might be surprised :) I've actually managed to find a torque spec for the drain plug on every car I've changed the oil on (I'm pretty sure, at least, there might've been one or two that I couldn't). Same reasoning, I bought the torque wrench, might as well use it.
The range is a bit surprising, too. I've had the specs as high as 29 lb*ft (in my 07 Civic).
Originally Posted By: bdcardinal
all drain plugs have torque specs. when i worked at sears, i always torqued drain plugs, a real cya thing.
Yup. W-M torques drain plugs too. We have a list with the makes and engines. Some of them Ive memorized. Honda ALL are 31 ft-lbs. Modular Fords are 10 ft-lbs. 6.6L Chev Duramax is 58 ft-lbs.
Sorry, I dont know an Alero. Dont run across them enough. If I had to guess, 18 ft-lbs.
The service manual does indeed say 18 ft-lbs.
The Alero is mechanically very similar to the Grand Am, by the way (the service manual is the same for both cars).
