2017 VW Golf - Spark Plug replacement - Oil in plug well #1
Texas
Hi everyone,
I changed the plugs today in my 2017 Golf. Upon removing the coil on cylinder one, I noticed a more-than-usual amount of oil in the well. You'll have to forgive the not so great photo of the well. I was against the clock trying to get this done before I got heat stroke in my garage, and I was getting the shakes from being hunched over my engine for an hour...
Is this something I should be concerned about? When I was removing the old ones, they did not feel like they were torqued to spec (dealership did them last 4 years ago). Torque spec is 30NM, and these felt hand tight and "snugged down". It took very little effort to remove them, so I feel that may have something to do with it. The other 3 plugs look fine though, no issues there, but they didn't feel tight to remove either.
Hi everyone,
Time for a cam cover reseal. Those 1.8 Gen3 EA888s didn’t have an actual gasket, just the anaerobic sealant.
This guy has a 3 part video on YT that covered this repair in great detail.
Gen3 EA888 cam cover reseal
Cam cover needs to be resealed? Not a fun job on those from what I recall...
Ughhhh. It's not causing any issues yet. I get more misfires from cylinder 2 and that one was bone dry.
It will eventually cause a misfire, so yes, you'll need to address it.
It's not causing any issues yet. I have OBDEleven and I checked and while it did have 1 misfire in my 15 minute spirited driving test, cylinder 2 had 7 misfires for whatever reason. I'll keep an eye out for it though.
Yeah I'm probably just going to pay someone to do this. I'm gonna let it ride for now until it starts causing issues. My car is only at 60,000 miles too.
The newer ones switched to RTV. I resealed a EA888.3 60K ago with RTV and it is still bone dry.
Resealing it without removing the timing chain is pretty dicey but it can be done.
